I've replaced a bunch of light bulbs with LED bulbs (specifically, these: https://www.homedepot.com/p/EcoSmart-75-Watt-Equivalent-BR20-Dimmable-Energy-Star-LED-Light-Bulb-Bright-White-3-Pack-1003020602/303701036) and am now experiencing occasional flickering on some of the dimmer switches. All the wiring in the house was re-done in 2013 during a gut renovation, and I am using the same model dimmable ecosmart LED bulb throughout. Also this is in the US. I've made sure the bulbs are screwed into the socket quite firmly, so I don't think that is the issue.
1 Answer
TL;DR Your Dimmers are Not Compatible with the Bulbs
Older dimmers don't work with most LED lights. Period. Many newer dimmers work together with newer "Dimmer Compatible" bulbs (as yours are listed). There are even some dimmers available today that are not LED-compatible, and 2013 or older dimmers are very likely to be not LED-compatible.
That being said, there are times when some combinations of LED-compatible Dimmer and Dimmer-compatible LED aren't quite compatible enough. But my hunch is that a new, good quality, LED-compatible dimmer will solve the problem.
Feel free to post the model # of one of the existing dimmers, as that may confirm the problem.
1Yes agreed. I had this same problem. A new dimmer I bought on Amazon did not work with some new LED bulbs, but was fine with others. Switching the dimmer for a locally purchased one (at a somewhat higher price) solved it. To the OP: a bit of experimentation with combinations will likely solve it.– P2000Feb 26, 2021 at 2:23
1OTOH, I discovered that my old skewl rotary dimmer that I'd been using for my ceiling fan lights worked perfectly well with the new ceiling fan and dimmable LED bulbs that were supplied with it (no recollection what brand/model the bulbs were). I updated to an LED compatible dimmer since this was the 3rd of 6 fans being replaced and the others had been updated, as well, but I was surprised that it worked just fine with no apparent flickering at all. For a short time, at least. (This answer does have my +1)– FreeManFeb 26, 2021 at 18:13
