Pools of water have started to appear next to the base of my toilet. There are two screws near the base of the toilet. One of them is totally loose (see photo) - it just spins and I can waggle it around and it doesn't seem like there's anything vaguely near for it to screw into. I'm not sure what it is meant to screw into. Other information:
- It might not be the loose screws that cause the water to pool - the cistern gets a lot of condensation - perhaps the water is then dripping off there to the floor. I've tried to confirm isn't not this by using a towel to 'catch' the condensation and water still appeared on the floor, but it's not a perfect test.
- When I flush the toilet, water doesn't come out of the screw holes or anywhere else.
- The toilet does not rock when pushed.
- I can't figure out what the toilet brand is so can't look up a manual etc. On the inside of the cistern lid it says "L34" but have not been able to use that to find the brand.
