Following up on my previous question about tiling over the tub lip I am trying to figure out how it is all going to fit together. Below is the bathtub picture. The long edge is going to be against the external wall.
The wall is Brick > Air gap > House wrap > Studs with glasswool insulation > Lining? > Bathtub
I am at the stage of installing the lining. I am confused about how to get the lining to sit on top of the lip so the tile can go over.
- Secure insulation in place with straps, slide the tub against studs, install the lining from the ceiling to the lip.
- Install the lining, slide the tub against it, install 2nd layer of lining to the lip?
Originally I was going to waterproof the wall and floor and slide the tub against the wall, tile to the lip or maybe even behind the tub, and silicone between the lip and tiles.
