Our plumber discovered that the drain pipe under our bathroom sink (which is done properly with a P-trap and vent) has a second P-trap down in the crawl space, which is incorrect.
I've been researching this and understand that having two in-line P-traps can cause drainage problems because air gets trapped between the two traps and water can't push it out.
However, in this case, there is a vent between the two traps, so I think that particular problem may be ameliorated. It's still done incorrectly though, and I'm trying to assess the risks.
What other problems could this second P-trap cause?
  • It could be a pain to get a snake down that line. Is there something else on that line or any reason for the trap?
    Commented Feb 23, 2021 at 15:18
  • settling of crud causing a clog Commented Feb 23, 2021 at 15:18
  • I had this in a previous house. It was 1941 construction. I could only guess that the underfloor trap was the only trap when originally installed. When an under-sink trap was later installed, given the vent, the effort to remove a (now) very old cast iron trap inside the basement ceiling was "deprioritized". Just guessing.
    – jay613
    Commented Feb 23, 2021 at 17:03
  • Debris is more likely to settle in the second trap due to lower drain velocity at that point
  • It's more difficult to clear debris there because you can't conveniently disassemble the trap
  • System cleanout with an auger is impeded by the extra trap bends, which tend to be sharper than other underground bends
    So the result of those issues would be slow draining or a completely clogged drain that is potentially impossible to clear with an auger? Commented Feb 23, 2021 at 17:15
  • Yes, though the actual likelihood of a problem has more to do with type and condition of plumbing.
    Commented Feb 23, 2021 at 19:06
