Is that reducer coming out of the meter necessary? Currently, it's a 3/4" to 1/2" reducer, then steps back up to 3/4" and then to 1" for the runs in the house. Can I eliminate this reducer and just go from 3/4" to 1"? Did the guy on the truck just not have the right sized fittings the day of the install?
Further Info if Needed: I'm in the middle of a remodel. I am going to move away from the black pipe and replace with CSST. We are moving FAU, moving the water heater, going from tanked to tankless etc. I'll be running new CSST. I'm just trying to eliminate some of the unnecessary fittings and turns if possible at the meter.
Thanks for the help!
