-1
This bathtub drain gets stuck whenever I try to pull it out. Is there a different removal method to get it out besides turning the drain anti-clockwise? enter image description here
    why would you keep trying to pull it through the hole? ... it looks too large to pass through
    – jsotola
    Feb 23, 2021 at 1:13
  • 4
    Looks like the part that removes from above is already removed. If you want to remove the "drain shoe" (part below/outside the tub) you either need to come in from below or take the tub out. I honestly can't even imagine what you think you are accomplishing in this picture....?
    Feb 23, 2021 at 1:34
  • Unable to remove push-pull stopper from tub drain ? Picture w/o the tool in it? Is that actually drain pipe, or what's left of a stopper? - "You would pull hard up on the assembly and twist counter-clockwise, Pulling the assembly up with force, while twisting counter-clockwise, might apply enough fiction to grip the retaining nut below. The issues then become can you access the area beneath to lock the assembly back in place."
    – Mazura
    Feb 23, 2021 at 16:50
For anyone curious about this; this isn't a traditional tub drain. Usually they unscrew and can be lifted out of the hole so that they can be replaced. https://www.instructables.com/Replacing-Bath-Tub-Drain/ I am not sure how common this style of drain is, but to fix you need to cut out the drain from below.
  • This should probably be edited into the original question or a comment instead of as an answer.
    – gnicko
    Nov 23, 2021 at 1:37
