I'm redoing my laundry room, and planning to put a butcher's block style counter top above the washer and dryer. The plan is for the counter to extend the full width of the room.
Questions:
It has to be removable to get at the back of the appliances, so I am assuming this would mean putting a ledge on both walls and mounting the countertop to the top of it (maybe with bolts that can be removed). What kind of ledge would I need? 1x4's mounted to studs? Would I need support in the middle, for a 6' span of 1.5" thick counter?
Does the counter need to clear the top of the washer/dryer by a specific amount? The dryer is electric not gas.
