About a month ago, I embarked on a mission to paint my half bathroom. Before I could paint, I had to remove the floor-to-ceiling wallpaper AND wallpaper on the ceiling. I successfully removed the wallpaper from the four walls but ran into a bit of trouble with the paper on the ceiling. I scored the ceiling wallpaper with a Paper Tiger and sprayed Zinsser Wallpaper Stripper, but, as you can imagine, the solution didn't absorb upward into the paper. After two weekends of scraping, I've removed half of the wallpaper and scraped several areas of drywall paper off too.
I'm now considering a different approach. Should I put a piece of drywall over the existing drywall? Or should I rip the ceiling drywall off and replace it?
Do you have any recommendations on this approach? Should I consider something else?
