I have used Sherwin William and DAP caulk but it keeps peeling away from my baseboards.
What is a good type of caulk that will not separate from the baseboards? The baseboards are painted with Sherwin Williams Divine White semi-gloss paint. This will make the 3rd time I've replaced the caulking.
enter image description hereenter image description here
  • Are you caulking the base to the floor? if so, that is the problem
    – Jack
    Feb 20, 2021 at 3:47
  • @Jack - I agree. I also think if you have tried the same thing that many times, time to move on. Never used that brand but the $3 premium brand at big box works pretty well.
    – DMoore
    Feb 20, 2021 at 5:17
  • You might try cleaning the area with alcohol before caulking. Perhaps with at Q-Tip. Feb 20, 2021 at 5:46
  • Which Dap caulk are you using? If it is the cheapest alex caulk that is why. I would use the dap extreme stretch or white silicone both which have much better flexibilty
    – redlude97
    Feb 20, 2021 at 6:00
If the caulking isn't applying to the paint, you can try scuffing the paint just below the top of where the caulking would affix with 120 grit sand paper. However if the floor is moving it could be pulling the caulking further than it is designed to stretch. For the latter issue, is your goal:
  1. Aesthetic, you prefer to have a seamless transition between the floor and the baseboard
  2. Sealing, you need a water or airtight finish?
For aesthetic reasons like an uneven floor with minimal vertical movement, you can try using quarter-round to follow the contour of the floor. Or remove the baseboard altogether and scribe the bottom of the baseboard to match the contour of the floor, then cut and sand to fit.
For aesthetic reasons like a moving floor that slips horizontally, or a need to have a watertight/airtight seal, remove the baseboard and use clear silicone bead against the wall and floor. Then apply a vinyl/rubber baseboard with some pressure on the bottom lip that will allow for flex. You could also use a rigid baseboard as pictured, that is scribed and cut to shape to match the contour of the floor, then reapplied as the silicone bead is still wet. Silicone has some flex in it and when done "blindly" will tolerate movement better than face sealing.
If the floor is meant to be floating, like many wood laminate snap together floors, and some linoleum floors, you may not be able to use caulking for a seal at all. If water/air tight seal is required, the floorboard may need to be raised slightly and a closed cell foam or rubber strip is used to make the seal, then concealed behind a quarter-round face at the bottom of the baseboard. This is why many commercial baseboard applications are done with vinyl baseboards, which can accomplish a degree of both water tightness and flexibility for floor movement.
