I've seen a few walls that use the top method versus the more common stretcher/running bond, are there any benefits to doing it the first way?
How tall is the wall going to be? Will it be mortared or dry fit?– FreeManFeb 16, 2021 at 12:01
1m and it will be mortared– Fony TinlayFeb 16, 2021 at 12:16
#1 is better than a stack bond I guess but the popularity of #2 isn't an accident...– MonkeyZeusFeb 16, 2021 at 16:09
gobrick.com/docs/default-source/read-research-documents/… seems resourceful– MonkeyZeusFeb 16, 2021 at 16:10
Add a comment
