My house came with 1/2 inch EPS board already attached to concrete in our basement. Instead of ripping down, I would like to frame over foam with 2x4 studs and fill with rockwool. Per code I need R13 minimum in zone 4A. Is keeping the EPS board on concrete a problem here?
  • I would just leave the XPS in place and put the batts in over top of the XPS. What was your plan for a vapor barrier?
    – SteveSh
    Commented Feb 15, 2021 at 20:59
  • This question is fairly common. Here's a related question.
    Commented Feb 15, 2021 at 21:01
    No, not a problem at all. There is a few things to consider with the overall assembly however. Here is a good resource, with more links at the end. google.com/… And yes, the rockwool is a great substitute for unfaced batt mentioned in the assembly diagram.
    – Blobfish
    Commented Feb 15, 2021 at 23:52
  • @Blobfish -- maybe you could expand that comment into an answer? Commented Feb 16, 2021 at 0:49
