Doing a remodel in our formal dinning room and need to remove an outlet. Once outlet removed, outlets in other room don’t work. Once I reconnected the outlet other outlets worked. How do I remove the outlet without affecting the others?
Connect the wires as they were on the outlet (using wirenuts, or another approved connector type if preferred) and use a blank junction box cover over the box (you must leave the junction box cover accessible.)
