Given the additional information in your comment:
The reason I want to insulate is because I have room above the garage which stay colder than other rooms in the house. I have checked the garage ceiling and attic and they both are insulated. The only part in garage which is not insulated are the walls. So I am thinking insulating the walls will keep the garage little warmer and in turn the room above will be little warmer than what it is currently now. And by the way on cold day my garage temp goes to 35-40F.
You should look to insulate the room itself - by which I mean look to insulate the walls of the room itself first, then improve the insulation of the floor system, then address the garage below. It's not that it's a bad idea to insulate the garage walls, but the garage door and the slab itself are still going to be too great a thermal suck for an unheated garage.
Go ahead and insulate the walls as long as they're open. It might help a bit if you have the money to throw at it, but pay particular attention to insulating at the top of the wall to continue the insulation plane across the whole floor system, right now it's probably missing at the exterior walls above the top plate and below the bottom plate of the room above.
Solutions in order of greatest impact would be:
- Thermal decoupling for the entire building envelope - I know, impractical, but I want you to get a better understanding of what the challenges to solving your problem are, not just getting a "yes you can insulate the walls for some advantage" - this entails installing insulation under your siding, over your sheathing and moving your WRB outboard of the insulation.
- Thermal decoupling for the garage ceiling from the floor of the room above - drop the drywall on the ceiling, fasten insulating foam to the bottom of the joists, ensure you maintain fire code before covering, reinstall the drywall with longer screws, tape joints to code.
- Air seal and replace the fenestrations, especially the garage door, with a better insulated and better sealed door.
- Insulate the perimeter of the foundation, minimum 2' below grade against wall, but in an ideal world with all the money you would retrofit as a frost protected shallow foundation.
- Insulate the bays in the garage walls.
So the upshot here is not that you shouldn't insulate the bays in your garage wall - as long as you have the walls open, you should absolutely throw it in there - it's just that there are a lot of factors that could net no noticeable impact despite that time and money spent, particularly that the amount of thermal loss from a room above to the garage below at only 35 to 40 is going to be very minimal. There's something else going on. If you were at -35 or -40, you would see a bid difference, but with your reasonably temperate temps, you should be looking to add to max-out the insulation value of the framing directly around room itself first and foremost to the greatest extent affordable to you.
