My filter system is leaking and I have switched off water supply to it for now. As a result I am not getting water in refrigerator as well. My refrigerator doesn't have filter inside it, this is the one that is connected to it.
My question is should replacing these filters pretty much fix the problem or I need a plumber?
Also how do I shop for new filters? Mine has a set of three as you can picture and the middle one appears to be a different size. It has code 11350 written on it. Is that how I identify new filter? Are there any compatible ones? I guess they may a standard type?
