I've recently purchased a home that has two hot water heaters - one at each end of the house. One in the garage, one in a closet. They're both showing their age, and both cost quite a bit to operate. My goal of this change is to make sure I have equipment that's not on the verge of failure, while also making sure that my energy usage is as efficient as is practical.
What comes to mind as an option is to replace the one in the garage with a heat pump/hybrid water heater (something like this), and run a recirculation pump to the other end of the house, removing the existing second hot water heater entirely.
Does this seem practical, or should I consider something else?
I'm in Florida; do not have a gas hookup; I have grid-tied solar @ 12KwH.
