I need to use some rebar, driven into the ground, to support a metal sheet:
 ______________________________________________________________
|                                                              | <-- thin aluminum sheet
|        ||                         || <--rebar next to sheet metal
|________||_________________________||_________________________|~~~~~~~~~ <-- ground
         \| <--rebar underground    \|
What is a good, strong way to affix the rebar to the sheet metal?
Your intentions aren't entirely clear, but here are some general ideas:
  • U-bolt clamps through holes in the sheet and around the bar
  • Hose clamps through slots in the sheet and around the bar
  • Wire through holes in the sheet and around the bar
  • A friend with a welder (though the dissimilar metals make this challenging)
  • Bolts through the rebar and the sheet
  • Screws through the sheet and into the rebar
  • Wire around the bar from below the sheet to above
  • How does a bolt go through rebar?
    – Village
    Commented Feb 3, 2021 at 20:49
  • Right behind a drill bit. Rebar is quite soft.
    Commented Feb 3, 2021 at 20:53
