I have a Hans Grohe Lacuna faucet. We love it, but it's started to run slow recently. There's a filtered water tap that uses the same cold water supply, and it's running fine. I assume it's the faucet. I cleaned out the aerator, but that seems to not have fixed anything.
1 Answer
The Lacuna (and possibly other faucets) has a backflow check valve assembly in the hose. There is a lacuna_maintenance pdf from hansgrohe that shows how to clean it. No tools needed, other than maybe a small brush for cleaning. Details not in the maintenance sheet:
- the blue cap thing has an o-ring. It's tiny; be careful to do any work over a plugged sink to not lose it down the drain.
- the two white things are backflow valves. Mine were so sticky that the valve was stuck. Only after cleaning did i realize they were valves.
- if you’re dirty enough that you have low pressure, rinsing with water probably won't fix you, you'd need a stiff bristle brush to actually get any detritus off.
1Hey, thanks for posting this. Please be sure to give yourself a check mark so others know it's been resolved.– FreeManCommented Mar 5, 2021 at 14:18
