I have a 3" wide area the height of the bathroom wall behind at the corner of an existing shower on the external wall without insulation. The space runs the full 8' height I can only reach the top 8" or so that is above the shower wall. Is it a problem that this space is not insulated? Any recommendations how to fill the space to the floor with insulation and provide a vapor barrier?
  • Remove the shower and build the wall right
  • Or forget the vapor barrier and blow in cellulose.
If you really want a probable horror show, spray foam it, but I would not recommend that if you don't want a horror show - it will probably overexpand and warp or crack the shower enclosure.
If you don't insulate it that will be an uncomfortable shower (I've lived with that junk in places I didn't build. Would not recommend.)
  • It appears that the shower is installed with some drywall screws, so it shouldn't be terribly difficult to remove, so long as there's access to the drain from below.
    Commented Feb 2, 2021 at 13:24
