I had a metal shop built and I would like to add a garage door opener for the roll-up doors but because of limited room between the top of the roll-up door and the roof, I am not sure if one will fit. I don't currently have a good picture of the issue but with the picture provide does anyone have any ideas? I was planning on mounting it vertically where the motor would be above the roll-up door but I think I don't have enough room. Any ideas, Suggestions? enter image description here
    Openers for rollup doors are usually on the end of the door spool, right? You don't mention space there. Also, this question is really dependent on product availability. You should research those options or ask a local overhead door shop.
    Jan 29 at 21:07
