I'm adding CAT6 networking to my house for higher speeds plus some POE cameras. I want to put the cable modem, switch and camera DVR in a metal structured wiring enclosure. The best place is the the gap between the studs next to the main breaker box so the enclosure and breaker box would share a stud. I've checked and there's no physical reason I couldn't install the enclosure there.
Are there any reasons not to put electronic/networking devices directly next to (separated by a stud) the main breaker box? Interference? Code?
