I framed a new wall over an existing wall to get a nice, rectangular recessed area for a projector screen in my basement. Here’s the wall prior to spackling:
Wall, Pre-Spackle
The old wall (back wall of recessed area) is extremely bowed, and so I read that I could use a drywall darby (and a lot of mud) to level it out. While I used powdered setting type mud on all my taped joints, I wound up using pre-mixed all purpose joint compound for leveling, mostly out of convenience. I realized that this would result in some cracking, and it certainly did. It’s also taking a really long time to dry, but I’ve got time.
While I believe/hope that the cracking will be fixed with lots of iterations of sanding/spackling, I’m more concerned with the left-most wall (pictured below), as I got a bit carried away with the drywall darby and obsessed over a quarter-inch gap in-between the left and the right vertical corner beads (I likely built them up too much).
Wall after mud leveling
In retrospect, I feel as though I should have just installed quarter-inch pieces of drywall and feathered them in.
Questions:
  1. Should I continue down my current path and with spackling/sanding until everything is nice and smooth? Or should I try and remove all of that dried mud somehow, at least on the left wall? I’d really like to avoid taking down any drywall panels at this point.
  2. Do I need to prime the wall with anything different than the standard, run of the mill paint primer considering all of the joint compound? I know that skimming with thin layers can provide a really smooth finish, so I’m hoping that’s still the case with thicker coats. For the sake of same texture everywhere, I’ve tried skimming the top and bottom pieces, as well as the inside frame pieces...
Try not to judge me too hard, and I’d appreciate any help!
  • You are supposed to skim coat in thin layers with the Darby or knife. If it takes a long time to dry and it cracks you are applying it too thick. Might take 3-4 coats.
    – redlude97
    Jan 26, 2021 at 5:54
  • My dad did a ceiling in pre-mix and it all fell on his head, use the setting type veneer plaster.
    – Jasen
    Jan 26, 2021 at 6:26
First, it shouldn't crack. If it does your putting to much on at once. Id also stop using all purpose mud after your first coat and switch over to plus 3 to make sanding easier on your body. I definitely wouldn't scrap off the mud you have already put on. If you want to sand some mud off Id probably get a finish sander and sand some off if necessary. But go easy on the sander. You can screw things up real quick if you go crazy. A pro would never do this but then again a pro wouldn't make your mistake either. Skim coat with plus 3 a few times, sand it and don't worry about it being two perfect. A wall is never perfectly flat and the only guy that's going to notice it not being perfectly flat is you. As far as primer goes I'd ask the guys at wherever your buying your paint. Normal primer probably will be fine but I'd go with drywall primer.
  • Some formatting and spell check would go a long way toward making this readable. That wall of text is... hard to digest.
    Jan 26, 2021 at 12:41
  • Thanks. I’ll switch to the Plus3. Will the walls with all of the joint compound be any more or less prone to issues (like cracking) in the future?
    – littleK
    Jan 26, 2021 at 14:11
  • @FreeMan geeze, somebody got up on the wrong side of the bed today. I didn't have any trouble reading it. Jan 26, 2021 at 14:34
  • I guess you must have, @GeorgeAnderson. Asking people to clarify their writing is not uncommon around here. In this age of tech, where everything has spell check, there's no reason for misspellings. When we're all under house arrest and cannot pick up on non-verbal communication clues, clear communication is particularly important. Whether you're asking someone to provide free help or you're providing the help on something that's potentially dangerous or expensive, being clear is critical.
    Jan 26, 2021 at 17:44
  • In regards to your question about cracking in the future, I'm not sure as I'm not a professional drywaller. However, I have made the same mistake as you before and after sanding and skim coating a few times things turned out fine and so far no cracking has showed up. Id just make sure when you skim coat over the crack make sure you get mud into the crack. If you leave any air pockets your asking for trouble. Jan 26, 2021 at 20:43
