How do I remove this type of screw? These are on the corners of a bed frame we are trying disassemble
bottom picture ... insert phillips screwdriver ... turn clockwise– jsotolaJan 24, 2021 at 21:26
Doesn't work just tightens it– DavidJan 24, 2021 at 21:30
1It could be a driven in insert that is not designed to be removed. A hole is drilled and the insert has fins that help to hold it in the shoulder on the driven side keeps it from pulling through.– Ed BealJan 24, 2021 at 21:37
what's on the other side?– JasenJan 24, 2021 at 22:21
1@David what happens if you turn counter-clockwise?– jsotolaJan 24, 2021 at 22:45
Show 8 more comments
