-1
We had a 2-story extension built, complies with earthquake code in Oregon. It only has a sub-floor right now but the impact noise from the bedroom to the kitchen downstairs is shocking.
The final flooring will be engineered wood planks. We are putting down noise-impact underlayment with an IIC of 72, but we would have happily paid for a stronger construction.
  • Please edit this to actually be a question. That's the way the site works.
    Jan 24 '21 at 21:39
    "but we would have happily paid for a stronger construction." Thank You for let us know. Is there a question that you meant to ask?
    – Alaska Man
    Jan 24 '21 at 22:09
  • learn to step lightly
    – jsotola
    Jan 24 '21 at 22:47
  • Wearing soft footwear and learning to walk quietly - I weigh over 100kg but make less noise than some females who only weigh about half what I do...
    – Solar Mike
    Jan 25 '21 at 5:09
  • @jsotola and if the new bedroom was built to give their kid more room for martial arts practice (or anything other than sitting/lying/tiptoeing)?
    – Chris H
    May 17 '21 at 15:10
Tip: speak to your contractor about spacing the joists closer together and put in blocking. Or anything else to reduce impact noise. The code is not good enough!!
  • accoustic insulation in the ceiling and thicker plaster may help too.
    – Jasen
    Jan 24 '21 at 22:46
