My (approx 25 year old) shower currently has a common handle style on it (the clear/crystal type); I pull the handle out to start water flow and twist to adjust water temp. It is essentially this style, with (I believe) a Moen 1225 cartridge:
https://www.amazon.com/LASCO-Simpatico-31661P-Chateau-Escutcheon-Polished/dp/B0083GDBP4
I'd like to replace it with a type of handle that levers out and the lever handle then rotates to adjust the temp. Is this possible? I ask because I see lever-style replacements available, but those pull out and then twist in essentially the same way/function as the current handle, and I'd like something that lifts/levers to start the water flow instead.
