The reverse osmosis installation instructions state
if you have garbage disposal then install the drain saddle before it
Unless I am misunderstanding what "before" (or after) means, it is unclear to me how I could ever install drain saddle before garbage disposal in my case as it looks like this:
Two questions:
- Does it mean I have to install drain saddle in dishwasher hose? Obviously it would not work on the ribbed hose.
- Alternatively, are there Reverse Osmosis faucets that would have two holes where second hole would simply drain directly in sink?
