I bought a lamp that I see needs a 3-way bulb. I don't really know what that means, but I see that the switch turns three times. Is using a regular bulb in it dangerous?
By the way, GE makes a most exceedingly excellent 3-way bulb. It is LED and is "150W equivalent" at the high setting. The trick is, it switches Low-High-Medium, which means if you put it in a simple 1-way socket, you get full brightness. Not cheap but the quality is so good that you only have to buy it once. – Harper - Reinstate Monica Jan 17 at 19:36
Most of the time, with most 3-way sockets and most "one-way" light bulbs, it's fine, other than you click a few extra times to turn it on and off.
Some of the time, due to manufacturing tolerances and the like, there can be a problem with the contact for the intermediate ring shorting out as you switch through the 3-way settings. It's not terribly common, but I have seen it happen more than once.
But other than shorting you have not seen any fires or anything of that sort? – Burt Jan 17 at 13:44
I've used single filament bulbs (one way) with no problem...but why not just buy a 3 way bulb and take full advantage of the fixture? – George Anderson Jan 17 at 14:18
1@GeorgeAnderson, because sometimes you need a working lamp right now, and can't wait for the store to open so you can buy a three-way bulb. – Mark Jan 17 at 17:26
a three way bulb has an extra filament and provides 3 brightness levels, if you use a regular bulb it will work ok, but only give one brightness level.
1Sounds like a brake light lamp for a car, where there is one ground and two live connections, each connected to a filament of different brightness. – Criggie Jan 17 at 11:43
