I would like to know if Arc faults and circuit overlords are the only potential fire starters directly related electrical wiring failures or issues? I ask this assuming any device plugged in is not the issue (ie, appliance).
If this is the case does a afci (outlet or breaker) and standard breaker provide almost full protection? (I leave out gfci as I have not read that being related to fires but instead shock hazards)
I am including an updated list of electrical fire starters below based on the answers for benefit of other readers. These are direct underlying causes of ignition under the assumption appliance/device is operating correctly:
- Arcing
- High amperage overload
- Continuous amperage load over certain efficiency level of gauge wiring
unforeseen circumstance
