Previous owner decided to recess the hinge plate below the previous (larger) hinge plate. While the door closes, you have to pull it closes otherwise it will "spring" back open. The door makes contact with the jamb (on the hinge side), which I believe is caused by this.
I am going to go buy some new hinges, but how to I make the jamb look decent, while still having it functional to put on new hinges? I read this post for some inspiration.
I was thinking of filling the entire recessed portion with body filler and starting from scratch. Is there a simpler method I can do? I read about cardboard etc, but I imagine that looks terrible and is not a long term solution.
