I have a receptacle in my kitchen cinder block wall and have chiseled a channel in the cider block for the Romex™ but I think the Romex™ needs to be in conduit like in this picture.
https://www.energyefficientbuild.com/images/RosO1-20080919-013a.jpg
Do I need to put a cover over the chiseled channel before I plaster over it or can I plaster right over the conduit?
  • Can you clarify if this is a picture of your actual installation or if this is something you grabbed off the internet somewhere. If it's just a "representative picture", please show us pics of your actual install.
    Commented Jan 15, 2021 at 16:30
  • That picture is the actual install. The link is off the web.
    – john
    Commented Jan 15, 2021 at 16:45
NM can be in the hollow cavity’s of block walls but not embedded in a cutout. When run in block walls, if exiting the wall conduit would be needed on the outside unless a surface covering is provided (a furring strip on either side with 1/2” plywood or Sheetrock) is another way to do it. Your actual work might provide more detail.
  • I can put the NM in conduit and secure it to the wall. Is it ok to cover the 3-4 inches of conduit that is cut into the wall with plaster?
    – john
    Commented Jan 15, 2021 at 18:36
  • You can cover the conduit in plaster that is ok if conduit was not used “nail plates” to cover the nm wiring would be rwquired.
    Commented Jan 15, 2021 at 21:00
  • I like the idea of the nail plate directly under the receptacle to cover the wire in the channel of the cinder block. I can put the rest of the wire in conduit but I was wondering, since the wire will be behind a kitchen cabinet and won't be exposed, does code require it to be in conduit? I understand the reasoning of conduit if the wire is exposed but if it's behind a secured cabinet you can't accidentally come in contact with it.
    – john
    Commented Jan 16, 2021 at 12:51
  • Behind a built in cabinet would not be exposed. I have attached furring strips to concrete then screwed plywood to the strips to cover electrical work. Is the receptacle above the counter in that case a couple inches of nail plate to protect the wires would meet code.
    Commented Jan 16, 2021 at 16:28
  • Yes, the romex is behind and below the counter. I will get some nail plates to cover the romex in the channel cut into the cinder block going to the receptacle. I will then attach the romex to the wall going down to the floor and into the basement. Thanks Ed.
    – john
    Commented Jan 16, 2021 at 16:41
