We live in a 2 level home with basement in central washington. The winters average 20-36 degrees Fahrenheit with humidity levels of 70-99%. Summers are fairly warm to hot with lower RH.
Our issue is condensation on our vinyl double pane windows upstairs. All of the windows upstairs have condensation and subsequent mold buildup which is becoming concerning to us. The issue does not happen downstairs where we have a wood stove. The humidity downstairs is usually 30% and upstairs is 50-60%.
We have vent fans in the bathrooms, and also heat with central furnace most nights when the stove burns out. The air return for the furnace is on the main level (between the basement and upper level), and there is no return on the upper level.
It seems to be an above average tight house built in 1997 but we haven't done any air tests on it to know for sure.
My question is: What would be a good option to mitigate some of this excess moisture on the upper level? The windows are fine, not excellent but not interested in replacing those. We just need to decrease the humidity on the whole upper level.
From my research, it seems like a HRV air exchanger may be the best option. I could install in the attic and duct to each room to get some air exchange. We do out best to limit moisture producing things, I think its just a catchment for the moisture in our house in general.
Thoughts? Whole house dehumidifier? ERV? HRV? Something different entirely?
Thanks!
