Lummox that I am, I went and put this dent into the wall. It's only a millimeter or three deep, but covers several square centimenters, and also reveals the underlying metal angle at the corner. Any tips for products/techniques to repair this?A shallow scratch in the corner of a wall
    Get and use the brightest work lights you can find. When it looks good under bright lights, it'll look great under normal light. And move that guitar to a safe place. And get a guitar stand. Commented Jan 13, 2021 at 5:39
  • " And move that guitar to a safe place." 🤣 It's my GF's ukulele, I'll get her a stand for it, thank you for the suggestion, she's hard to buy presents for : )
    – LiavK
    Commented Jan 14, 2021 at 20:07
All you've done is "Knock the Mud Off". The thin layer of joint compound on the wall.
I would use Spackling and a flat bladed putty knife.
Spackling
Putty Knife
There are plenty of YouTube videos on how to do it.
I would get a small batch of mud and fill in the damaged area. The reason for the mud is it will absorb primer and paint the same as the original wall. After you fill in the damaged area, roll over it lightly with a 3'8" nap paint roller to give it a bit of that orange peel texture that already exists there or dab it with a sponge. You might have to experiment a bit to get it just right but what the heck... Rome wasn't built in a day.
First remove any loose or damaged areas with a utility knife. Cut loose pieces at an angle so as to leave a shallow bevel on the sound wall.
Brush away any loose dust and debris.
Using a wide drywall blade (8-10 inches) or putty knife (4 inches) press fresh joint compound into the damaged wall section using the very tip of the tool in a horizontal swipe.
It may take several swipes (passes) to get the proper results. Ideally you want to slightly over fill the divots and depressions. The compound has a tendency to shrink slightly as it dries espacially for deep cracks.
Let the repair dry over night. Lightly sand the dried epair so that it is level with the surrounding wall. Use your hand to confirm this or a light source held at an angle to the patch will highlight any imperfections.
If needed apply another coat and repeat previous steps.
Prime and paint with 2 finish coats.
