On 15th December 2020 we became aware of a burst pipe on the side of our house. The source of the leak was the cold water pipe leading into the hot water system on the side of the house (brick veneer). I believe that the pipe had been leaking for about 2 days, and the temperature during this period was approx. 30°C (we're in Australia).
My wife noticed the sound of running water late at night - I investigated and found the leak. We noticed the the plaster board wall in our bedroom (directly opposite the leaky pipe) was quite damp and had slightly leaked out on to the floor (but was fairly contained, and easy to mop up with a towel).
I immediately turned off the water supply, and a plumber came the next day to fix the source of the leak. The plumber said there was a lot of dampness in the wall and he recommended I file an insurance claim to deal with the dampness and possible mould issue.
When I looked at the meter, it had registered 3 months of water usage since the last meter reading (which was 2 months ago). So a 50% increase in water usage over the 2 month period.
The insurance company sent a company with a dehumidifier which ran for approximately 2 days straight (except when going to sleep) pointing at the wall. Prior to the dehumidifier running, they used a moisture detector on the wall and it had an extremely high reading. After the 2 days, they came to collect the dehumidifier and it was still measuring a high reading (but they took it away as it was Christmas and we were going on holidays). They said at this point, the dehumidifier didn't appear to make a difference and recommended someone come to look inside the wall.
A few weeks later someone came and did another moisture test and the reading was close to "normal". This was corroborated with a plumber who used a thermal moisture detector and couldn't detect any moisture in the plaster, but detected a very slight increase in moisture at the skirting board (pictured).
Yesterday, someone attended again and said that because there was no signs of mould on the outside of the skirting board, they don't believe there is any mould inside the wall cavity (as mould would likely show itself on the outside of the skirting board). The said they could remove the skirting board to look inside the wall, but based on their observations they don't think it needs to be done.
The skirting board spans the entire length of the bedroom wall, and removing it is not a small job as it may damage the plaster.
Based on what I have outlined above, is the insurance company right when they say the probability of mould is low in this scenario? My biggest concern is any potential health issues caused by the mould. I'm not sure if this is a case of "I can't see anything, therefore it's probably not there" or if they are just cutting corners here.
Photos below of the skirting board in question, and the source of the leak.
Skirting board looked at by insurance Source of leak at hot water system
9
  • Questions. Is brick wall in sun? is house on slab or stumps?, is there insulation in wall (not likely)? are there ceiling insulation batts covering wall cavity (like it should). Jan 12, 2021 at 22:07
  • @PolypipeWrangler - brick wall is on East side of the house so gets sun. House is on stumps. Not sure about insulation or batts. It's an old house (build in 1964). Jan 12, 2021 at 22:09
  • if in southern parts of Aust, I feel that wall will dry internally easily. Ceiling batts installed to standard are supposed to cover top of wall, but usually dont. You can tell by lifting a roof tile and seeing. I feel that critically bad level of moisture would be indicated by plasterboard collapse. Jan 12, 2021 at 22:15
    The cases I saw with good recovery in Ivanhoe (Melbourne) in Dec '18, were flooded to 5 cm depth, treated with big heater fans for three days, and on slabs (not stumps). I feel optimistic. Surely the insurance company would have to pay for replacements if they were wrong. @Ed Beal has more experience than I, and he agrees. Jan 12, 2021 at 23:52
    A few weeks is time enough to know that the mould hasn't grown. Jan 12, 2021 at 23:55
The inside walls of your home will have mold spores from day 1 keeping the home well ventilated and dry keeps the mold from growing. If you look in your attic you will probably see some black spots that’s mold. Mold needs moisture to grow if the wall is dry it won’t grow so at this point if the area is dry there won’t be mold growing since it sounds like there was no insulation to hold the moisture. With that information having remodeled many homes both for myself and professionally the insurance company is most likely right. They would not want to have the wall covering to start failing when it could be a cause of this pipe failure. And further damage resulting from not doing things right the first time. So I believe they are correct and you will have no problems.
