I spray WD-40 on metal parts in a high moisture area to prevent rust. But in one particular case, I don't want the oil getting on other things in a tight area, so I'm reluctant to use the spray. Is there like a non-spray equivalent of WD-40 that I could smear on by hand or coat with a paint brush to the thing I want to protect from rust? It should ideally protect against rust for several years without requiring any more applications.
  • You can purchase wd40 in gallon cans – Kris Jan 12 at 23:29
    Someone actually using WD-40 for what it's designed for? I was about to jump in with "WD-40 is rubbish for that, you really want <X>" which applies in almost all cases... but protecting metal by displacing water is actually what WD-40 is for. Do keep it off plastics unless you want them damaged. – Harper - Reinstate Monica Jan 12 at 23:49
    Although now that I said that, I think what you really want is Rustoleum 7769 Rusty Metal Primer. Only have to apply it once instead of weekly, and it applies with a throwaway bristle brush. – Harper - Reinstate Monica Jan 12 at 23:53
  • coat with a paint brush to the thing I want to protect ... what is preventing you from spraying WD-40 on the brush? – jsotola Jan 13 at 21:23
Spray onto a cloth or rag and wipe on.
Avoids any overspray if you prepare the cloth/rag away from that area.
  • wouldn't the rag absorb most of it though? Is there a particular type of rag that would work best for this? I guess I could put on some disposable latex gloves, spray on the gloves, and then wipe on – public wireless Feb 9 at 19:39
You can buy WD-40 in gallon cans that are not aerosol spray. These are meant to refill manual pump spray bottles, but you can use it in the way you proposed of course.
But if you want it to stick around for longer, it might be better to use something like actual grease or even paint. WD-40 is pretty thing, and does evaporate.
  • only problem is a gallon is way too much! – public wireless Feb 9 at 19:40
Cosmoline. Or grease, but cosmoline is (now) formulated specifically for rust prevention.
Petroleum jelly or Vapo-rub are moderately effective and perhaps easier to clean off, not to mention being available at any drug store or grocery store.
