I have tried to locate a manual (as seen in the picture) on FAAC's website. The model number XF 433 turns out to be the code of the radio module.
At the moment the a swing leaf gate it controls is not responding. I suspect it is caused by a blown fuse due to a recent storm.
Where is the fuse and how can I replace it? Do I need to remove the radio module (XF 433) before I take of the frosty plastic cover?
15
    why don't you take off the cover and look for a fuse?
    – jsotola
    Jan 9 at 2:58
  • Do you mean the frosted plastic cover? I am not familiar with the unit, so I want some instructions. Jan 9 at 3:00
    it's not rocket science ... wiggle the cover ... look for latches or screws at places where the cover appears to bind ... otherwise, call a gate service tech
    – jsotola
    Jan 9 at 3:07
    Most of us won't have specific experience with a given piece of hardware -- but it turns out engineers who make hardware tend to follow patterns. We learn to identify those patterns. There are a red+black pair of wires going to the top, near where the frosted cover says POWER. Through the cover we see an array of cylinders with silver tops; both of these things are signs that the board's power supply is in that area. If the board has a fuse on its input that's the area where it'll almost certainly be found. Figure out how to remove the cover and have a look.
    – Greg Hill
    Jan 9 at 3:35
    @ojait House voltage. Jan 9 at 3:41
The fuse is located under the logic board. (see attached photo)
It is actually not necessary to remove the frosty plastic cover of the logic board. As a matter of fact, removing the cover incorrectly could bend and damage the pins of the radio module.
The fuse is a glass fuse T2A.
@Anthony Kong- There is a fuse. It may be resettable or replaceable. Here's your link for the maanual. Let me know what happens or if I can help.
  • 5
    I'm not a downvoter, but link-only answers (which this is basically) are discouraged since links can die. I'd suggest going though the manual and transcribing the fuse information into your answer,
    – DoxyLover
    Jan 9 at 7:35
  • yeah it takes half a minute to copy a screenshot from a pdf or web page into an answer, less if you can cut and paste text.
    – Jasen
    Jan 9 at 11:14
  • @ojait Actually, I am correct. Here is a direct quote from the help page on writing answers: “ Always quote the most relevant part of an important link, in case the external resource is unreachable or goes permanently offline.”
    – DoxyLover
    Jan 9 at 23:18
  • I said "link only answers are discouraged" not "link answers are discouraged".
    – DoxyLover
    Jan 10 at 2:05
  • this is an answer with a link. i answered "there is a fuse..." and shared a link.
    – ojait
    Mar 11 at 22:40
