I changed out the switch on the light fixture in my bathroom, and the fixture no longer works. Prior to my changing the switch, both the old switch and the fixture worked fine. I'm trying to figure out the root of the problem.
I tried swapping the new switch for another new switch. No change.
I tried swapping the fixture for another fixture. No change.
That suggests the issue could be a problem with the wiring between the switch and the fixture, but that seems odd to me -- what exactly would the problem be?
There's also the possibility that I'm somehow messing up the wiring of the switch somehow. This seems more likely -- human error! -- but there are only two wires here, a red and a blue. My understanding is that the red one is the hot wire and therefore the blue one is presumably the neutral, but the information I've found online about blue wiring is a little hard to decipher. See the attached image. There is also a GFCI outlet (which still works fine) in the box.
This is the light fixture box. There is no blue wire here, so I gather there is some sort of junction in between the switch and the fixture.
Finally, I discovered an old fixture box behind a (bad) patch in the drywall. I'm including an image here in case it is relevant. I note that there is a blue wire at the top of the box, and if this was the fixture used before the new one was installed, it would make sense that current is being routed through this fixture to the new one.
Here's how all three boxes in relation to one another on the wall.
I'm going to pick up a non-contact voltage tester today and try to diagnose further. Right now, I'm just planning to see whether current is actually making it 1) to the switch, 2) through the switch to the old fixture, 3) and through the switch to the new fixture.
Any other suggestions on how to figure out what is going on here? Since this was working a short time ago, I'm hoping I can fix it myself, but I will bring in an electrician if turns out to be more complicated than just installing a switch or fixture correctly.
  • Can you provide a picture of the fixture box?
    – JACK
    Jan 8, 2021 at 19:22
    Don't ever assume a blue wire is a neutral. Big, big chance you're wrong.. lol
    – JACK
    Jan 8, 2021 at 19:24
  • Did this start because the old switch/fixture wasn't working? Or was everything working but you wanted to change the switch (which is fine, but is a different situation)? Do you still have the old switch? Jan 8, 2021 at 19:30
  • @JACK I added a photo of the fixture box, as well as a photo of what I am assuming is the old fixture box that I discovered behind a crumbling drywall patch. Jan 8, 2021 at 21:44
  • @manassehkatz-Moving2Codidact the old switch worked fine, it was just ancient, discolored, and ugly. I have about ten old switches from my apartment, not sure exactly which one came from the bathroom. Jan 8, 2021 at 21:45
It looks like you have two circuits, black and blue wires and a white neutral, coming out of the center conduit in the old fixture box. The black wire is wire nutted to a group and one of them goes up the left conduit with a neutral to the switch box to feed the GFCI outlet. In that same conduit is the always hot blue and what will be the switched hot red when hooked up to a switch. The switched hot in the old fixture box leaves in the lower left along with a neutral to the new fixture box. Check your main panel for two breakers that energize the old fixture box. They may not have handle ties on them
    THANK YOU! The issue wasn't the breakers, but your description of what is going on in the old fixture box sort of clued me in to the bigger picture of how everything was wired together. That in turn made me realize that I needed to crack open the other light switch in the bathroom, and sure enough, the problem was there -- a disconnected blue wire. To anyone else going through something similar: buy a non-contact voltage tester BEFORE you start messing with switches and outlets. Not only are they excellent safety devices, but they take a ton of guesswork out of working with wiring. Jan 9, 2021 at 2:59
  • @HotDogWater -- write your conclusions up as an answer and I'll give it a +1 :) (extra helpful if you include photos of the other switch box's innards) Jan 9, 2021 at 3:02
  • @ThreePhaseEel good idea. Done! Jan 11, 2021 at 2:27
  • Repeating myself fro a comment on the OP: "Finally, I discovered an old fixture box behind a (bad) patch in the drywall." And that is why it is a CODE VIOLATION to bury a fixture box behind drywall! At some point, you may need access to this and will have to cut open drywall again to repair it. PLEASE make sure you put a blank cover plate over this (wall paper or paint it to disguise it, but leave the screws exposed), and do NOT bury it behind the drywall again!
    Jan 11, 2021 at 16:21
  • @HotDogWater Next time add all the details about work you've done to the question. If we had known you replaced those two switches in the bathroom, I would have directed you there instead of to the breakers.
    – JACK
    Jan 23, 2021 at 18:59
Now that I know what the problem was, I'm going to try to write up a more general guideline for complete amateurs like myself who find themselves in a similar situation. Let me begin by stating the obvious, though: if the work is more complicated than replacing a switch or an outlet, you probably need a professional.
Also, always flip the circuit breaker to cut off power before accessing any live circuits.
OK, to recap the issue: after replacing some ugly but working light switches in my bathroom, the vanity light fixture mysteriously stopped working. It was clear that something I had done caused the problem, but I had no idea what. I need to trace the issue to the source.
Step 1: replace the new switch with one I know is working to make sure the new switch isn't the problem. (It wasn't.)
Step 2: replace the fixture with one that is definitely working to make sure the fixture isn't the problem. (I bought a bare socket for $2 to test with. This wasn't the problem either.)
Step 3: if the fixture and the switch are both fine, then the problem is likely the wiring. It's helpful at this point to step back and understand how the wiring in the room fits together and what the wire colors mean. Let's start with the easy ones:
  • Black: hot or live wire, bringing power from the power source to the outlet or switch
  • White: neutral wire
  • Green / bare: ground wire
Now the trickier ones:
  • Red: these are also live wires. They can be used in a few circumstances, but in my case they indicated wires bringing power from the switch to a fixture.
  • Blue: another live wire, in my case indicating live wires pulled through conduit.
So the general flow of power in my bathroom looks like this:
  • Black -> outlet -> white
  • Blue -> switch -> red -> fixture -> white
Now also understand that switches and outlets in a room are usually connected serially. Knowing this, you can figure out the flow of power in a room.
In my case, I used a non-contact voltage tester to see which wires were actually live. In other words, I just touched this pen-shaped thing to each of the hot -- red, blue, or black -- wires in the chain leading to the fixture to see which ones actually carried a charge. And it turned out that none of them did. Not even the blue wire leading into the switch was live. (Side note: if I had the non-contact voltage tester to begin with, I could have saved a ton of time swapping out switches and fixtures, skipping steps 1 and 2 above.)
Once I realized there was no power coming into the switch, my focus shifted one step upstream in the chain to a fourth electric box on the wall that contained the switches for the bathroom fan and overhead light:
It hadn't occurred to me that these two switches, which were both working fine after I replaced them, would have anything to do with an unrelated fixture. But sure enough, when I cracked the box back open, I spotted the yellow wire nut connecting the three blue wires.
That is, now it is connecting the three blue wires. At the time, the third blue wire, the one leading to the downstream vanity switch, was disconnected, because I had forgotten about it and forgotten that the hot wires are connected serially.
Et voila.
  • You missed the most important step 1: Take pictures of everything before you remove any wires from anything!
    Jan 11, 2021 at 16:22
