I recently bought some smart recessed lights (with smart dimmer) for the kitchen. The smart lighting system requires the power supply to the lights always remain on. Rather than placing the smart dimmer somewhere beside the existing light switch, my preferred solution would be to place the smart dimmer directly over the existing switch location. In order to do this, I was wondering if there exists an "inside box" switch. That is, a type of switch that can be tucked completely inside an electrical box (which I could easily access and still turn off, if needed, by removing the overlying dimmer).
Edit: I had thought of just "hardwiring," (foregoing a switch completely) but felt that might have been unsafe. The answers indicate this is not a concern.
The smart system I purchased is Philips Hue (GU10 bulbs and Hue dimmer switch).
