I am using amaron 880v inverter with 1500mah Tall tubular battery when I connect my laptop 130w charger then room lights are flickering then I checked with another laptop 90w charger then same lights flickering is happening if I connect my 130w laptop and 90w laptop with out inverter then lights are not flickering
I buyed last month only new inverter I am facing from the first day then I contact customer care then they sended technician but no use he said I can't find the issue so other technician will approach me
What I need to do now and what issue I was facing with inverter
How to solve the issue
