I'm adding a 100 amp subpanel to my detached garage and have a question about the EGC I've already pulled through the underground LFNC-B raceway.
Taking the advice from a similar post on this forum, I decided to use a 8 AWG bare solid copper conductor for my EGC in the underground raceway back to the main house. The other 3 conductors are 3 AWG THWN-2 stranded copper. I did double check the NEC tables to ensure these were appropriately sized for the underground feed portion of my run and ensured the conduit fill was less than 40%. What I failed to realize though (until after I won the good battle of pulling this set though the raceway) was that there is a section in the NEC that prohibits the use of solid conductors 8 AWG or larger in raceways:
"310.3 Stranded Conductors. Where installed in raceways, conductors of size 8 AWG and larger shall be stranded."
Dangit! Now I'm questioning why I didn't just use insulated green THWN-2 - it would have made my pull much easier! Rookie mistake.
So how bad have I goofed up here? Let's say the inspector fails to call this out. Is this a safety issue? What's the rationale for the rule anyways? To prevent numskulls like myself from trying to pull larger gauge solid wire through a raceway and possibly damaging the other conductors? Or is there more to it? Interestingly, there seem to be several exceptions in the NEC that do allow for using 8 AWG solid EGC in raceways (690.46 for Array Equipment Grounding Conductors for example).
I'm just trying to get a feel for the severity of this goof-up and if it's worth fixing if not required by the inspector. Any feedback from the experts would be much appreciated!
