I have a one of those two-head spotlight fixtures in my back yard. The fixture is under my deck roof and never gets wet. Each socket is rated at 120 watts max. It's designed for the PAR38 spotlight bulbs.
I want to use a 90-watt PAR38 spotlight bulb (brighter light for the yard) in one of the sockets and a 45-watt A60 standard-size bulb (dimmer light for the deck) in the other socket. Is it safe to mix and match bulbs like this?
Some Google searching seemed to indicate that it's safe to mix and match wattages, as long as you don't exceed the fixture's maximum ratings. However, I couldn't find anything on mixing bulb types.
