Good day. I had to cut a piece of drywall on the ceiling to run some electrical. I used the same drywall patch (that I cut out) to repair the hole in the ceiling. I used mesh tape and joint compound (USG Plus3) to repair the hole.
Since the drywall is not new (had paint on it), do I need to primer the patch or can I just paint over it?
If I should primer, what would be the best primer for my situation?
