I have a door with 3 hinges that are 4 inches - 1/4 inch radius on the corners. Finding a specific hinge with the same hole pattern seems to be impossible to find or extremely expensive.
Is there any issue with using a 4 inch 5/8 radius radius instead? Obviously it would fit. But the reverse would situation would not fit.
Why exactly are their 2 or 3 different sizes corner radius's? Is it a structural thing or simply esthetics?
