What are the advantages/disadvantages between using a Junction Box Ceiling Light Installation or a Slim LED Driver box installation?
My ceiling has space to incorporate either option.
I am wondering what the best option is, is the industry going towards more LED Driver box ?
The Slim LEDs come with their own junction box.
Examples:
LED Round Color Select-able Flat Panel Recessed Trim
Ultra Slim 6 in. Canless Color Selectable CCT Integrated LED Recessed Light Trim Downlight 900 Lumens Dimmable
Slim LED with Driver Box:
Installation Video: https://www.youtube.com/watch?v=w4fHshRd3g0
Junction box Install
searching to understand comparison, vs. for new house
In both cases a box is required. The advantage today is the slim may be cheaper, but in the future you may be tied to a slim box. This could become a problem when all the mfg’s are only making replacement modules for full sized boxes because of the millions or hundred of millions of full sized boxes currently in use. How many slim boxes were ever installed?
The other consideration is that if other wires are in the box to connect to other lights, there is a minimum number of cubic inches required to accommodate those wires, so in this case, a larger size may be required today and provides more options when this light fails (LED’s rarely fail but the electronics driving them sure do).
  • thanks, so which one should I get? regular junction box, no slim led driver? money isn't really a factor for me Jan 2, 2021 at 0:04
  • btw, my slim LEDs I bought come with their own junction box I believe Jan 2, 2021 at 0:08
    @earlwaltonluv3462 if money's no object today or in the future, use whichever one you want. If you want to be prepared for the future, put in a large junction box & install the slim box inside it. That gives you the most options for the future.
    Jan 2, 2021 at 1:02
  • I agree with freeman that’s what I was trying to point out saving a small amount today may put you in a bind later. if you go with the slimline today and when it fails in the future cost may still not be an issue the inconvenience of a different style and possibility of having to add boxes could be a headache eliminated by installing boxes today. +
    Jan 2, 2021 at 6:47
