I've been working on wiring my shop in my unfinished basement (sub-panel installed by a licensed electrician) and I've come across a question I haven't been able to find an easy answer to.
There are places where I'm running down the length of a floor joist (at least 1.5" from the bottom edge, secured every few feet) and I need to change the side of the joist bay (to go through a hole in the joist usually). It's a simple crossing of the open air space between joists. Are there any code requirements or rules on how to cross the joist bay if the wire continues to run parallel to the joist for a bit on either side of the crossing?
I live in Ohio if that matters for the answers.
Thanks for the help!
