I have excessive water pressure and intend to install a Pressure Reducing Valve (PRV) on my 3/4" copper water line.
While looking at PRVs I noticed that some products feature SkarkBite push to connect fittings. I do not have all of the supplies I'd need to solder to the pipe so using a push to connect would save me from having to buy them. It may also be easier because I'd be working in my crawl space.
I live in central Alabama so we do not get many hard freezes, and the PRV will be in an enclosed crawl space that is warmer than the outside during the winter.
- Are PTC connections reliable long term for high pressure applications?
- Are there any other factors I should consider when deciding whether to solder in the PRV vs. use a Shark Bite?
- In practice, how easy would it be to replace the PRV if I connected it with PTC fittings, and would it be better to have soldered on threaded adapters if I need to replace the PRV in 10-20 years?
Edit: I ended up buying and installing a PRV with Shark Bite fittings. Here is a photo of my finished installation. I didn’t notice when I asked the question originally that the ball valve that was already there was also installed with push to connect fittings.
