We have wooden basement stairs that are probably 20+ years old and several of the treads are starting to split down the middle (underneath) lengthwise.
I'm debating replacing the cracked ones or just replacing all of them, but I'm having a tough time figuring out what would the treads are made of:
In case I decide to replace the cracked ones, I'd like the replacements to be the same type of wood as the others, so it looks more or less consistent (I understand new boards will not be as faded as older ones, but they'll still be the same type of wood, have the same grains, patterns, etc.). Any ideas what wood those treads are made from?
In case I decide the to replace all of them, I'm interested in what type of wood (and dimension) is generally recommended for basement stairs. The existing treads measure 1 1/2" x 9 1/4" so I'm guessing they're all 2x10s.
If you notice in the photo there are also no risers and I'd like to add some. Any recommendation for type of wood (and dimension) that are recommended for risers?
Thanks in advance!
