I'm looking for nice a way to cover this gas line plug sticking out of my wall. It's an eyesore that is no longer needed, I believe a leftover from the oven in an extra basement kitchen area. It sticks out about 0.75" from the wall.
I know they make domed cover plates for plumbing cleanouts (such as this), but those typically screw right into a plastic cleanout plug. In this case, it's a metal plug/cap. Ideally I was hoping to find something similar (domed blank cover plate) that I can screw into the wall with wall anchors. I'm not really sure what I should be searching for though. Any suggestions?
Gas line
  • depending on the fitting inside the wall you may be able to tighten the connector so that it is behind the wall. You'll need to open the wall to get a wrench on it.
    – ojait
    Dec 27 '20 at 23:06
I think if you remove the plug and replace it with a flush plug, then spackle the crack around it and paint. It would (IMO) be less obtrusive than a cover.
  • Yep this will make it flush
    – Kris
    Dec 27 '20 at 23:41
How about a surface mount double gang electric outlet box and a blank cover plate over it. Trim a hole in the back of the box to fit the pipe. enter image description here
