Help! I'm replacing some light switches for my kitchen light and I can't seem to get the circuit to work properly with the new switches. I assumed I just needed to buy two 3-way switches, but I can only seem to get it to turn on/off using one switch at a time. The wiring has hot wires coming into both switches - do I need to use a 4-way switch somehow? Unfortunately, I didn't take pictures of how the original switches were wired. Hopefully the images below are helpful - I verified each wire by testing them individually and connecting the hot to the other two wires at each switch.
Update: I think the switch by the outdoor light was a 4-way switch. Still can't get it to work with using the old switch.
