In my condo I have a heat pump with electric strips for auxiliary heat. When the outdoor temperature is quite cold, the heat never turns off. It reaches the set temperature, but keeps running.
When this happens, the aux heat turns on and off repeatedly. It seems like the same situation described here:
Question: Can anyone recommend a solution that allows adjusting the behavior of the aux heat (E.G. a separate CPH setting for the aux heat), so that the aux heat stays on longer.
