Hoping this is my last question on this topic - ref. Following-up from New Circuit Help Please - Feeding 2-gang receptacle boxes with MC 12/4
You kind souls saved me from myself. I’ll implement the “MWBC recovery plan” you recommended to overcome my screw-up — for having purchased 12/4 with a blue wire instead of a gray wire ... I thought I was going to be able to tape the blue wire with white or gray tape but learned via the aforementioned thread that you can’t tape over wire smaller than 4 GA (ref. NEC 200.6(A). Many thanks to ECnerwal, ThreePhaseEel, and Harper - Reinstate Monica for having my back! Thank you!
So, here’s the updated plan, annotated as a recovery plan so folks who find this some time in the future realize this was not the ideal solution. Don’t do it this way! Don’t be like me. Read the other threads first! This could have worked if I had bought the MC 12-4 with a gray wire. But I didn’t.
You’ll note that I clarified I’m coming from a sub-panel, and I’ll feed from a section of 12/3 romex (from behind the wall in an unfinished storage room).
Hopefully this third time is a charm. Sharing the neutral on this MWBC works because the 2-pole breaker feeds two hots 180 degrees out of phase with eachother, so even when pulling 20A from each of the hot legs (red and black), the shared neutral is pulling 20A while pushing 20A, so the net is 0A on the neutral. The max current on the neutral happens when only one circuit is pulling 20A. Looking for confirmation this is all good before I sign off and finish this installation so I can start making sawdust instead of smaller and smaller pieces of wire.
Adding this pic given @bigchief response below:
Assuming this means I can use one back- input for line and the second back- for continuing to the load, without using a wire nut.
Thank you all very much!
Sincerely, Rich 🎄🎄 Happy Holidays 🎄🎄
