I’m trying to mount my Samsung Frame above our fireplace. The placement of the studs makes it so the tv would be about 1 1/4 inch off center if I hang it with the included mount anchored into a stud on each end. If I went directly centered no studs would line up with any of the mounting holes. The tv is 55 lbs.
My main question is 1 1/4 inch off center going to be noticeable for 65” tv, over a 71” mantel, viewed normally from a couch 10-11ft away?
I’ve thought through some of these alternatives:
The Frame comes with a very specific no-gap mount that makes the tv tight to the wall and look like a painting. We’d like to use the no-gap mount, so that rules out 3rd party mounts. The included mount doesn’t allow for any lateral movement. It does have various mounting holes, but unfortunately but their placement doesn’t span long enough to allow for any studs to be hit while centered. Also wanting to keep the tv tight to the wall rules out mounting plywood across multiple studs and attaching the mount to that.
Update: I was browsing a store and happened to find that a third party makes the exact same no-gap mount. I was hesitant to drill holes in the OEM mount since that'd void the warranty. No qualms drilling the aftermarket mount.
This first picture is the mount lined up with the center of the studs(yellow lines) using the existing holes. You can see the center line is off center. Tv not centered using existing holes
This next picture is the mount and where the center of the studs(green lines) line up.The mount centered
If I drill a new hole on the top left side there'll be .56 inches of margin on the left side of the hole. I think that should be ok since the existing holes are only .4 inches from the top. Also since there's a taper, I'll need to move the bottom left hole in a bit and maybe hit slightly off center on the stud. Does that all sound alright?
If I'm trying to follow the manufacturers instructions I should add two sheetrock anchors in addition to the 4 stud holes. If I use anchors in the two center holes(my thumb is covering one) is there enough width between everything? I think it should be alright?
Thanks for your input!!
    There are studs on the front of the chimney?
    – DJohnM
    Dec 14, 2020 at 7:14
  • Get a different tv mount, one that provides a little side to side adjustability relative to the stud anchor location. Dec 14, 2020 at 15:17
  • @whatsisname If you wish to ignore "The Frame comes with a very specific no-gap mount that makes the tv flush with the wall and look like a painting." then sure...
    – MonkeyZeus
    Dec 14, 2020 at 15:20
  • Show us the mount, please. It's likely that you can put new holes in it for a simple fix.
    Dec 14, 2020 at 15:30
drill holes in the frame where the studs are. No way would I put a $1000 TV on toggle bolts.
  • I just found an aftermarket mount that matches where I can drill holes into and not void the warranty. Dec 24, 2020 at 0:26
  • Is the warranty on a hunk of steel really an issue anyway?
    Dec 24, 2020 at 13:44
  • No, I know sometimes to fulfill a warranty a manufacturer requires all OEM equipment be returned so using an aftermarket mount mitigates that. Dec 28, 2020 at 19:28
    Drilled holes in the mount where the studs are and hung it. Tested it and it's super solid! Thanks all! Dec 28, 2020 at 19:29
Any TV mount instructions I've read specify that you MUST drive the supplied lag bolts into a stud X number of inches. If you do not do this then you cannot hold the manufacturer liable for any injury that your setup might cause.
With that said I would cut out a section of sheetrock from stud to stud which is larger than the TV mount by at least 8 inches vertically and mount a piece of plywood that is as thick as the sheetrock to the existing exposed studs. Behind the plywood I would screw on short studs in the exact location that you require lag bolts for the TV mount.
Finally, mount the TV mount to the faux studs and give it a good slap as you say "that's not going anywhere."
If your wall is relatively thick (3/4 inch) and you want to sink your mount to make the TV even more tight to the wall then I would go no thinner than 1/2 inch plywood.
  • If this were 8" off (i.e., as far as possible from the studs) or some other serious problem then this would make sense. But it is an awful lot of work for 1-1/4" off center. Dec 14, 2020 at 14:59
    @manassehkatz-Moving2Codidact Whether it's 1.25", 8", or 2' off it doesn't matter. The serious problem is that OP wants to mount a TV on sheetrock. I'm not here to convince them to live with 1.25" off-center. OP has 2 choices: do it or do it right and I hope to help them achieve the latter.
    – MonkeyZeus
    Dec 14, 2020 at 15:02
  • OP has made it clear that if they move 1.25" then they hit the studs. Sheetrock over studs if 100% fine, safe and normal. Sheetrock by itself is a definite No. Dec 14, 2020 at 15:05
  • @manassehkatz-Moving2Codidact OP seems to be trying to rationalize toggle bolts and I am here to supply a firm "No". Given that they are worried about 1.25" off-center then I assume they are the type of person to notice or will uncomfortably live with knowing that it is in fact off center.
    – MonkeyZeus
    Dec 14, 2020 at 15:13
  • My impression is quite the opposite: That OP seems to be trying to rationalize being 1-1/4" off because they know that stud-mounting is the safe way to go. Dec 14, 2020 at 15:27
With a TV that big I doubt anyone (except you) would notice 1.25", even with just over 6 total exposed inches on the sides.
When I mounted our 70" Vizio where I wanted it was nowhere near the studs if the entire setup (mount and TV) was completely centered, but I found this mount below which was able to shift left or right I think 9 full inches. So I was able to get 4 total lag bolts in 2 different studs and it turned out great. Doesn't totally hug the wall but it's close enough for me.
https://www.amazon.com/dp/B07ZYR8F2W
    Wouldn't the viewer be comparing a 4.75"margin with a 7.25" margin on the other side? That's a 53% difference. (But over 5 feet away...)
    – DJohnM
    Dec 14, 2020 at 7:17
    Thanks for your input! Even if no one but me would notice I'd still need to be looking at it everyday and noticing it being off haha Dec 24, 2020 at 0:28
